Hi All,
I've an issue, I can't find where is the option to replace existing WorkSet Folder locations.. Maby someone knows where is it?
I came up to this issue, when I found out, that I can't press Browse button, only New File. I believe the issue is because of the root folder for Design Files.
OPM CE, Update 7.
Hi NerijusThanks for posting your query to Bentley Plant forum. During creation of workspace using the OpenPlant Project Administrator tool, it is pretty easy to define the desired folder location for workfiles or any. But once the location is finalized we need to manually edit the configuration variables. Please refer below provided wiki article that explains workflow to setup workfile/model location as desired.
Answer Verified By: Nerijus Petrauskas
Thanks, all worked.
Just strange that OPPA is needed to create a project (workset) but you can't edit it through it..
Does this still exist in Update 10?
Hi NerijusGlad it worked for you.The reason for not having that editable via OPPA is to avoid mistakes. Giving the flexibility to edit may result issues with configurations that are linked.Thank you
