Dear All,
I am encountering one proplem. I wanted to update or make changes of existing piping components came from vendor or consultant. For example, a valve or flowmeter. I first tried to drop the component to manipulate. But when I dopped it in OPM, it disappered. I treid turning on/ off display set. But the issue still exists. So whenever I wanted to do that, I opened that file on Microstation or OBD, it drops easily. But for me, it's quite troublesome to open/ close in OPM & OBD. May I know what is the issue with dropping on OPM. Any other ways to expedite the process? Thank you.
Thiha
Hello Kyaw,I will check issue of dropping components in OPM and let you know accordingly.Are the mentioned piping components (valve,flowmeter) modelled in OPM or are used from some other application?
Hi Vaidyar,
Thanks for reply. Not sure where those were modelled. I received from my consultant and needed it to be updated. Since they are piping components like valves, I believe they also modelled in OPM. I tried it on my machine by adding new piping components. And noticed that whenever dropped any piping components, it disappers. When they are dropped in OBD or Microstation, no happening. Is it one of limitations in OPM?
