Hi, when I visualize a cable successfully connected it showed me a correct route, but when I create a 3d cable solid the cable doesn't follow the same route. The cable go throught raceway and came back.
Hi David,
Thanks for posting your query on Plant Forum! We shall update after discussion.
HTH,
Rahul Kumar
Hello David,
Thank you for reaching out here with your query.It is a known issue and the development team is working on fixing this.
Please log a service request mentioning BRCM version and we will get back to you.
Regards,Aadarsh
Answer Verified By: Aadarsh Tale
