Hello All,
For OPPID (V8i) database migration to SQL server, I loaded SQL Server Management Studio and tried to connect the server "W10-OPM-U9-DS" as per the instruction given. Used the given username and password but it keeps failing to connect shoiwng error: 40 & 53. Please refer to below screenshot and kindly advise what to be done next. Thank you.
Thiha
Hello Kyaw,
Thanks for the meeting, as we observed SSMS not install with Multi-Authentication mode, that why not allowing to login with SQL login and password.
Steps followed for installation:
We have followed SSMS installation steps and add Multi-Authentication mode, further need follow below wiki link steps.
Hi Abhijit,
Thanks a lot for help from you and your team. Now SQL server connection issue has been solved. I will follow next steps for database synchronization.
