Pro structure - Version 08.11.11.207Object enabler version: pstoe081111207enWhile I extract the i.dgn file through Autoplant composer I get the error, that all objects are going to the corner location as 0,0,0 what should we do can suggest for a solution for this. for your reference I attached snapshot,Before extraction.After Extraction
Hello Rajesh,
Unfortunately screen shots are not clear, Can you Please upload proper screenshot so that we can understand concern more clearly.
Regards,Abhijit Bute
After extraction
