How to create a new 2D display fragment in BRCM for equipment? I create two elements and they do not work correctly, they are inserted from the same point
Hello Kirill,
Are you trying to create a new cell based equipment and are trying to add a 2D cell to it? Can you provide some more details on your requirement?
Please refer to the below wiki link for creating cell based equipment:
Hope this helps regarding your concern.
Joseph Gelacio
I'm creating a 2D element that I then output using the 2D Extraction command, but my 2D elements are made up of several components, such as a rectangle and two circles. When I use the 2D EXtarcrion command in BRCM, my circles and rectangle are inserted at the same point. I am attaching two screenshots, on one element from cell files, on the other a 2D element after using the 2D Extraction command/
You need to create two cells one for 3D representation of your equipment and one for the 2D and in your case both should look alike . You can follow the steps provided by Joseph to create cell based equipment.Here are my test result:
For further help please log a service request and we will guide you to achieve the required results:
I created 2 element. One for 3D and one for 2D, but when I do 2D Extarction my 2D element doesn't insert correctly. If there are two or more objects in the 2d element, then it inserts everything at one point. I am using upd 9 BRCM
Hi Kirill,
Try this at your end:
4237.CADLIB_ElectricParts.cel
Equipmnent.7z
