Can you please tell me if it is possible to change the PORT of a pipe insert (PIPE class) when placed in the model? By default the program inserts the PIPE class via MAIN_PORT, can I set it up so that users can choose between RUN_PORT and MAIN_PORT?
Hello Kirill,
Thanks for posting your question, we are evaluating your concern, we will get back to you soon.Regards,Abhijit Bute
Just press shift on the keyboard, it then places via run port first
In the PIPE class, this hotkey does not work. This hotkey does not work in elements that are built by Placement Type LinearPlacementTool and Handler Type Linear
Pipes usually have same EndPrep on both ends and maybe that is why OPM have the Placement Point disabled as shown in the picture. Are your end preps for the pipe are different?
Hi, Yes. Our end prepps for the pipe are different. Fjr example, for main port is SCF, for run port is SCM. How users can change them when works in OpenPlantModeler?
