OPM CE DOESN'T PLACE BOLTS ON WAFER TYPE (RING SPACER) CONNECTIONS USING MY CREATED FRP SPEC
IT PLACES GASKETS BUT NOT BOLTS, WONDERING WHAT AM I DOING WRONG ON THE CATALOG/SPECS OR IS THERE A SETTING ON THE PCF OR NEED TO ADD ON SCHEMA.
SOMONE HELP PLS, THANKS.
I FINALLY FIGURED THIS OUT, IT DOESN'T WANT MACHINE BOLTS, IT ONLY ACCEPTS STUD BOLTS. DOES ANYONE KNOW HOW TO SOLVE THIS? THANKS.
Dear Sammy,
Thanks for adding your Solution comment.
For MACHINE BOLT class to appear, you need to check how it is defined at JOINT class, However, for a Wafer end type connections, STUD_BOLT class is recommended.
You need to review if there is any WAFERED_LUG_END type connections available which may require both class types to be connected to.
HTH,
Rahul Kumar
