We're transitioning our V8i OPM builds over to Connect, but I haven't found how to create the Service list in the Schema as we do in V8i.
Is there something available to show this?
Hi Sean,
Thanks for posting your query on Plant Forum!
Are you looking for external database query to create a list of Service? How to Use External Database Query Custom Attribute in OpenPlant Modeler CONNECT Edition Applies To Product(s): OpenPlant Modeler CONNECT Edition Version(s): 10.07.00.32+ Environment: Windows 8.1/10 (64-bit) Area: OpenPlant Modeler CONNECT Edition … Last edited over 1 year ago in OpenPlant | AutoPLANT > OpenPlant | AutoPLANT Wiki
Kindly share more information as well if above doesn't help.
HTH
Rahul Kumar
Hey Rahul, hope you’re well mate.
I’m trying to find the steps for setting up and using a value map for service. I had a copy for v8i, but can’t find it. Wasn’t sure if it was the same process.
thanks.
Thanks Sean for Quick response
You need to create new Service Value Map and add entries. Further you may need to define it on Service properties to use it.
I will try to create new content and add it, meanwhile you can refer similar article for quick look How to Add a New Category with a Pull Down in from Class Editor Applies To Product(s): OpenPlant Modeler Version(s): 08.11.09.XXX(SS5) Environment: Windows 7/8.1 (64 bit) Area: Schema Subarea: - Original Author: Michelle… Last edited over 7 years ago in OpenPlant | AutoPLANT > OpenPlant | AutoPLANT Wiki
Also adding service values via OPPA you may use below How to Modify Value Map Using OpenPlant Project Administrator Applies To Product(s): OpenPlant Project Administrator CONNECT Edition Version(s): 10.06.00.23 Environment: Windows 10/8.1/10 (64-bit) Area: Value Map Subarea… Last edited over 3 years ago in OpenPlant | AutoPLANT > OpenPlant | AutoPLANT Wiki
Rahul,
Adding the Value Map is easy enough, but I'm still finding my way around the new PA interface.
How do I now link SERVICE_NAME to the lookup in Connect?
OkLet me test this and update
Thanks Rahul.
Are you able to confirm this one Rahul?
