Hello!I can not import Specification from Autoplant to OpenPlant.
I use Example Metric WorkSpace. May be you have special specification as there
docs.bentley.com/.../GUID-7FB59212-E330-4CDB-B035-2B631B10E9F4.html
Dear OlekSandr
Thanks for posting your query on Plant forum!
Can you help us with what version of OpenPlant You are using here?
From above query, what I understood that you are looking for AutoPLANT spec conversion to OpenPlant? Please confirm if that is true.
HTH,
Rahul Kumar
Dear Rahul!Thanks for answer!Yes, I'm looking for AutoPLANT spec conversion to OpenPlant.
CONNECTION Client 11.00.05.44
OpenPlant Project Administrator CONNECT Edition Version: 10.10.01.16
OpenPlant Specification Generator CONNECT Edition Version: 10.10.01.16
Best Regards,
Oleksandr Bilanovskyi
Hi OlekUsing OpenPlant Spec Gen you can use two possible methods based on your requirement.
From OpenPlant Specification Generator > Tools > Exchange SpecUsing this approach, AutoPLANT spec will be exchanged for use in OpenPlant Modeler based on existing mapping. In this workflow, you can not further edit the spec in spec gen. This functionality only adds the EC_CLASS_NAME column to each table records.From OpenPlant Specification Generator > Tools > ExchangeThis is the comprehensive way of exchanging the catalog to make it compatible with OpenPlant suits. Use the exchanged catalog and create spec from it.This workflow will allow the full flexibility to edit further edits of spec/catalog when needed.
