One user is using WVD machine and Open plant project administrator application does not launch under his ID. It shows in task manager briefly, turns into 'Suspended' state and never opens. (screenshot below)
I logged in to same machine and application works normally without any issues.
Tried recreating user profile with no use.
Anyone has any idea what could be wrong?
OK Try to look in to Event Viewer , maybe some more info we got there
Thanks Laeeq to suggest,
Hi Rakhi, can you please send it so that we can get it checked?
HTH
Rahul Kumar
Yes thank you, thought I attached the event viewer logs, here they are
Just to also try, below mentioned steps in the link were also tried with no luck.
https://communities.bentley.com/products/plant/w/plant_design_and_engineering__wiki/50369/to-fix-unhandled-exception-error-while-launching-pipeline-manager-in-openplant-modeler-v8i
Hi Rahul, Any thoughts??..attached the event logs
Laeeq, Any thoughts on the Event Viewer logs?
