I've added service.txt and services.txt to the settings directory, but when I create a new line the specs aren't being restricted to those listed in service.txt. Is there anything else that needs to be set for this to happen?
Hi Sean,
Please review below wiki to get some idea where you may need to use spec filter to restrict them based on service.
How to Associate the Specification Based on Service Applies To Product(s): OpenPlant Modeler Version(s): 08.11.09.XXX (SS5) | 08.11.11.XX (SS6) Environment: Windows 7/8.1/10 (64 bit) Area: Properties Subarea: -… Last edited over 5 years ago in OpenPlant | AutoPLANT > OpenPlant | AutoPLANT Wiki
HTH
Rahul Kumar
Perfect, thanks Rahul.
