I'm trying to create a deployment for OPIM U11 using the /layout switch but that seems no longer work. Any advice would be greatly appreciated.
Best regards,
Tuan Le
Hi Tuan,
Thanks to share your concern. You mean if you try with below example which includes /layout and not working?
"D:\Setup_OpenPlantProjectAdministratorx64_10.10.01.016.exe" /layout (this is just shown as example)
RegardsRajesh Agrawal
Answer Verified By: Tuan Le
Found the issue, I was using the wrong slash.
Thanks Tuan and great to hear that it is resolved. Here is Wiki link to refer same process.
(+) How to Create Deployment Image for OpenPlant Isometrics Manager CONNECT - OpenPlant | AutoPLANT Wiki - OpenPlant | AutoPLANT - Bentley Communities
