How can turn off the display of this spec break between a nozzle and a pipe?
I am running OPM U8 10.08.00.51 with OPIM 10.09.00.74.
Justin
Hello Justin,
Thanks for your question, can you please provide us L00 file for further testing.
L00 files find under isometric output location in L00 folder.
Abhijit Bute
Hi Abhijit , how can I send you the file?
I found the setting in the style.cfg file:
Thanks Justin to confirm, Yes you can manage it through that.
Also adding wiki for your reference as well
Managing Spec Breaks on Isometrics Drawing Applies To Product(s): OpenPlant Isometrics Manager Version(s): 08.11.09.440 & Above Environment: Windows 7 64 bit & Others Area: Settings… Last edited over 8 years ago in OpenPlant | AutoPLANT > OpenPlant | AutoPLANT Wiki
HTH
Rahul Kumar
