When connecting an existing pipe to a connecting model that is referenced. It is not generating a weld/connection point. A weld/connection is created when a new pipe is connected to the reference but that does not seem to be the case when an existing pipe that has been modeled already is connected to the ref. Is there a work around for this?
Justin
Hi Justin
Thanks to post your question in Community. I can see that you have also raised Service request 7001518921 for the same.
Sameer is working on your issue and will reach out to you today for the meeting.
Rajesh Agrawal
