Hello!
After experimenting with the creation of a new class, I got a problem with the generation of isometrics
Can anyone tell me what the problem is?
Best Regards,
Alex Bilanovsky
Hi Alex,Thanks for posting your query on Bentley Plant Forum.Can you please provide additional information like what class you are creating and also what procedure you are following to create a new class.Can you share the .dgn file with us by only placing the custom component which you have created.HTH,Chanchal Mashalkar(Global Technical Support Engineer)
Hello Oleksandr,
Are you using U11?
Hi, Gaurav!Yes, U11
Hi Chanchal,I've done many actions before I found out that isometric generation didn't work:Tried making a gas flow straightener like orifice plate. And I have added the project parameter and then valveBut isometric generation works when opening a project with another wokrset. The problem comes out in the workset and I'm wondering how to repair it. This is a standard workset OpenplantExample MetricBest Regards,Alex Bilanovsky
Please make sure you have the following lines in your OpenPlant_3D_Supplemental_Isometrics_Isoextractor.01.08.ecschema.xml
If not, please add them as per the snapshot below. This should fix your issue. Please let me know otherwise.
<L00_LABEL_SECTION_LABELS xmlns="OpenPlant_IsoExtractor_Custom_Attributes.01.08"> <LBL_SECT_LABELS /> </L00_LABEL_SECTION_LABELS>
