Hello!I`ve done New VAD on New Setting Name from OpenplantExample. When I want to preview Top View with Display View, I have a message "VAD file not found"
Then I did "Drawing Generation". And after that I did Update Draw Position, and now I have other 3D Clipping Area and other Output PositionWhat can I do with it? I can't save 3D Clipping Area and Output Position. And that`s why I can't generate OrthoThat is new generation after updating positionBest Regards,
Alex Bilanovsky
Dear Alex
Thanks for posting your query on Plant forum!
You may try below wiki to verify on creation of VAD files as well as to see on how to edit it.
Please check above links and updates us if still an issue here.
HTH,
Rahul Kumar
Dear Rahul!Happy New Year! Now it is 2023!The link is about version 08.11.11.87 (SS6) and it has 6 years old. My version is 10.11.00.153 Connect Edition. It is new, but it doesn`t work.And it has other interface.
Maybe you can make a new example and check how the application works in user mode, can`t you? After all, usually the designer works in this mode (as user). Basically, designers in large companies do not have administrator access rights.
Best regards,Alex Bilanovsky
Hi Rahul!Thanks for the article! It will be great for all users. Thanks for Quick Answer!I have a practical interest in where the data on 3D Clipping Area is stored. I lose them when a drawing is generated. I wonder if the user has access to the folder where the data is locatedBest Regards,
Hi Alex
Can you confirm what is project Unit? Are you working with Mixed metric Project?
Rajesh Agrawal
