Hello! I have decided to check how the manager works on the built-in example!And what I have: If I create a new view, I have crash! And this crash doesn't go away until I remove the view.If I do new generation on built-in example view, I have this
OPOM CEU11 is like the Boeing 737 MАХ 8
Best Regards,Alex Bilanovsky
Dear Alex,
Can you confirm which DGN file you have used here? is it default one?
Kindly help us with the steps you followed here to open it so that we will verify it.
HTH,
Rahul Kumar
Dear Rahul,Yes, It is default DGNBest Regards
I have had similar results in U10 trying with PW managed workspace. I do recall that one of the example projects was a bit better but can't remember if it was metric or imperial.
Kris
Thanks!
