Hi!Has anyone had this problem with the display? Top view fine, isometric view not so muchDisplay Styles: Illustration (Monochrome too )
In Smoth Modeling:
Best Regards,
Alex Bilanovsky
Hi Alex,
I have tested the same but looks ok here. Can you check if some resolution settings are different?
or you may also check with other DGN and update us.
Please let us know
HTH,
I had trouble with Isometric generation. Bentley recommended to return to the original configuration. Now I can generate Isometrics! But... And in new dgn I have good look. But old projekt with new configurations has such problem. I think I should copy some files from old configuration, but don`t know which
the reason was the mark to show Plan view in View Setup
Can we have meeting today to discuss on this issue.
