Is there a way to customize symbols for the types of welds that are shown in OPM? For example, a field fit weld will appear like this whereas other welds are simply a sphere. It would be great to visually distinguish the type of weld instead of having to check in the Properties window. A problem also exists when the connection between the pipes or piping components are modified and the weld is recreated with the default weld. The designer cannot tell what kind of weld it is with a generic sphere so it does not prompt the designer to change the type to the correct weld.
Justin
Hi Justin,
you want to differentiate between SHOP and FIELD weld?
in this case we do not have anything direct. however we can check if something we should offer.
HTH
Rahul Kumar
Good day Rahul,
Yes, the ask is to have the ability to change the symbol based on the type of weld whether it is SHOP or FIELD or FIELD_FIT. Can we add it as an enhancement request? I can log it if you wish; please remind me where to submit the request.
Thanks again,
