I'm trying to connect flange from existing spec but gasket on this size is not available. I can't seem to figure out how to add it in Gasket in Spec Gen. I have tried copying the size from another catalog to this catalog but it's still not working. Please know that I only have 30% knowledge of what I'm doing so I appreciate if someone can guide me around Spec Gen to add this gasket. Thanks!GTYPE = 'GAS' AND MAIN_SIZE = '200mm' AND RATING LIKE '150LB' AND FACING_1 LIKE 'RF'
Hi James,
Thanks for posting your query over Plant forum.
Can you please add more information here
a. What Application you are using and which version
b. How you are copying catalog to catalog
recommended way is to user Catalog Editor. However the other way around would be -
1. to open mdb file and copy GASKET Table and paste that Table inside other catalog.
2. add further in spec using spec gen
3. save & close spec
Try the results
if still something would require do let us know.
HTH
Rahul Kumar
Thanks for your response.
A. I'm using Autoplant Modeler Connect Edition.
B. Our "OFFSPEC" Spec Table does not have gaskets for the size I have mentioned so in Catalog Editor in Spec Generator, I copy several rows from another spec of gaskets for those sizes and facings.
James
Hi James,Thank you for the information.I would request you to log a Service Request for this issue.You can refer the following wiki article for logging a Service Request : (+) How to log Service Request? - LARS | LEAP | OpenBridge | OpenTunnel | RM Wiki - LARS | LEAP | OpenBridge | OpenTunnel | RM - Bentley Communities
Sameer Pantawane
