It seems group/ungroup piping components turn them un-editable. Attached is a sample file. The lower right line is actually a pipe element modified after being ungrouped. The model was created using example Metric workset. I don't suppose this is by design of the software.
Best regards,
Tuan Le
balnk.dgn
Hi Tuan,
Can you share the following:
Thanks!
Fer
Hi Fer,
OPM 10.10.01.39
steps:
place some pipe run
select some pipe components
group (ctrl+G)
ungroup (ctrl+U)
modify any component by edit handle will corrupt it.
Hi, just wondering if there's any update on this?
I have replicated the issue in the OOTB. This issue in OPM U10 is currently under review by the Product Management as it was flagged by other users as well.
Thanks for the update Fer. just wondering if same issue exists in U11?
