Key-in to Update/Refresh Tagging
I am making changes to the valve annotation in the schemas to move the positions of the various attributes that we are displaying on the P&ID.  Is there a key-in command or any other function to run on the P&IDs to update the annotation that has already been placed on the P&ID?  For example, if I change the height of size annotation of the valve to be 2 mm higher than its old position, can I run a command to refresh the annotation on the P&ID so the size annotation of all valves will be in the new position?
Before refresh, the size is in the original position based on the schemas:
After updating the schemas and running a command to refresh:
The update applies well to newly placed valves but I would like the software to update the annotation automatically to save the Designer's time from manually adjusting the annotation.
Justin
Parents Reply Children
