Tag sets and Text Nodes Iso
Just Curious if there is a way to add a text node number to a Tag set tag,
I am looking to populate an isometric with specific text nodes in the title block when it is run and the existing titleblock was using a Tag set to enter the values, I am checking if there is a method to associate a specific tag with a text node number so that it will fill in the data based on the isometric properties when created.
