I was experimenting withI've always run single line number "B" size isos but I've been experimenting with system isos on "D" size formats. I created an alternate .MLD and .POS file to move the text to the right place but left all the other configuration files alone except to set the .OPT file "D" size and to redirect the file pointer for which format to use. Everything seemed to work except it looks like it is not using the .DDF file to set layer colors etc. and in the PDF file it is not setting the material item codes (they are all set to 0) and the material code chart at the end of the file is not filled in.
Can anyone point me in the right direction to debug this?
Brian
In the DDF file, make sure that you spell the color value the British way, colour. As for the other issues, it would be best if we could get your files and run some tests on them. I would also recommend that you contact TSG and get a service ticket created for this. We can continue replying over the forums as well so that others can see the progress.
