Is it possible to create a weld list with the OPM Isometrics?
Chris,
Yes, it is possible to create a weld list and have it placed on the isometric drawing.
Ian Robinson
Ian, I can't find the configuration setting to enable this feature. What is the entry needed in the project iso configuration files?
Chris
Depending on which isometric style you are using...I am going to refer to IFC, just replace with your configuration
C:\Documents and Settings\All Users\Application Data\Bentley\OpenPlantModeler V8i\WorkSpace\Projects\OPModeler_Metric\DataSet\Isometrics\Styles\IFC\Config
Modify the file report.def
Add in a section to determine what you want to see in the Weld Report, Assign it to a text Node, and then place that text Node into your seed file. Setup the text Node with the Font, justification etc that you want for this report.
You will have to enter in the attributes you want in the wled report. I have just copied the CUT report form above and modified a bit to give you an idea of what to do.
# The WELD report lists the Welds
# Attaches to text node 62
REPORT = WELD
INCLUDE = IE_TYPE=CT_WELD
COLUMN = 6:C:CUTID
COLUMN = 7:R:SIZE1
COLUMN = 21:R:QUANTITY
COLUMN = 3:R:
COLUMN = 80:W:IE_DESCRIPT
GROUP = CUTID
SORT = CUTID
NODE = 62
END
Thank, You Alan.
I tried this and works Ok. However I would like also to have the welds individually numbered on the Isometric line. Is this possible? It was a standard feature in Isogen.
Is it possible to get a tutorial/manual with all OPM isometrics configuartion options.
Chris I will send you an email with a copy of the session I did last week at Be Together. If others would like a copy, please drop me an email, as i cannot upload an attachment right now for some reason. Alan.Leonard@bentley.com
