Hello All,
I was wondering if there is a way to edit the SHP_FLD field in SpecGen XM. Something similar to Edit Catalog.
Hi James,
If you want to override the catalog values you can add the field in the description field using the field manager, and then ovride the values similar to long description
Rx
Vishal
