Can you package an existing SQL Central Mode Project into MS Access to give to a client ?
Using V8i
Yes. A SQL project can be packaged then unpackaged into any database type that AutoPLANT supports.
Project packager is not database specific. When packaged the database information is converted into XML files. When the package is unpackaged the data can be imported into any supported database (SQL, Access, or Oracle) from the XML files.
