Hi!
I started up an old project in Plant XM to make some changes. There are some strange things happening..
If I open the file via Document manager it´s enough to click on one pipe to get thrown out;"Fatal error", but this i can solve by open the AC application first, then the pipe model, then piping. Also, many of the pipes have lost their line number so i can´t really see what is what.
Anyway, the problem is that i can´t export isos. I get the following messages:
In the Export Progress window it says like this:
Info: XCHG0504: Export File: C:\Documents and Settings\All Users\Application Data\Bentley\Plant XM\xchg\pcf\ISO-100-1-NDA40BR011.PCFInfo: XCHG0504: 13 components exportedInfo: XCHG0504: 0 errorsError: XCHG0504: ISOGEN Errors:Error: XCHG0504: Personal ISOGEN failed while running ISOGEN module (Code -2)Error: XCHG0504: [Personal ISOGEN error -2]Error: XCHG0504: ISOGEN message file saved to xxxxx\Config\isogen\final\FINAL.MESInfo: XCHG0505: Completed export on Mon Dec 05 15:18:13 2011
Info: XCHG0504:Info: XCHG0504: Export Summary:Info: XCHG0504: 1 export filesInfo: XCHG0504: 13 components exportedInfo: XCHG0504: 0 errors
And in the Final.mes file it says as follows:
Personal ISOGEN : VERSION 6.3.0 (Full)
*** IDFGEN VERSION 7.3.0 (Build 13) ***Reading File: ISOGEN.PCF
Processing PIPELINE-REFERENCE: ISO-100-1-NDB40BR061ALL COMPONENTS CONNECTED.ISOGEN VERSION 9.3.0 (Build 42)********************************************************************************ERROR:Message Indentifier: ISOGEN:1115Message Text: UNABLE TO OPEN ISOGEN -161 FILE xxxxx\Config\Isogen\FINAL\FINAL.ASC RUN TERMINATED
Any clues anyone?
Thanks/Patrik
