Just started using PlantSpace Design Series XM 08.09.04.17. I like some of the new changes in Raceway, like the ladder cable tray, however my horizontal and vertical fittings doesn't draw with "rungs" like the straight sections of tray. This makes for a very unprofessional looking presentation in the model. It looks as if we made a mistake or that our software is not as sophisticated as other software used by our competetion. Is this something that will be addressed in a several of years with the next version, or do we go back to using the solid tray even though in real life that is not what we are using?
TIA
[V8i SS4 08.11.09.829, BRCM, Promis-e, OpenPlant Modeler, OpenPlant PID, STAAD, RAM, ProSteel, InRoads, FlowMaster, Map, PondPack, StormCAD, Descartes]
Hi Mike,
It released about one hour ago. You can go and get it from SELECT Downloads.
Ian Robinson
Ian,
Just got .34 loaded and running. Problem solved. Thanks
