Shows : evaluation version of ComponentOne:VSFlexGrid8(Light) version:8.0.20111.281
Respected Bentley Team ,
We are facing the typical problem in the specgen in autoplant.
  • It shows the evaluation version of ComponentOne:VSFlexGrid8(Light) version:8.0.20111.281, as shown in attached screenshot.
  • Also we are not able to update ,as shown in attached screenshot second.
Note : FYI :
We recently upgrade our software and hardware to
 Software : Autoplant V8i - SS4 version : 8.11.9.140 ,  Autocad 2012-64Bit , Naviswork 2013 , MS-Office 2010 64 Bit Win7-64bit
Hardware : Workstation Dell Precision T3600
Please let me know where the problem arise.
 Waiting for your earliest reply.
  • Hello Swapnil ,
    Component One issue should be resolved in AutoPlant 08.11.09.140. Are you able to reproduce this using any catalog or only specific one?
    Could you please give more details on Update field case? Is it not possible to enter data in filed? What field you are trying to update?
    Please upload catalog so I try to reproduce this on my side.
    Artiom
  • Respected Bentley Team,
    We are already using the latest version.
    A>
    We also try by admin login, then also same evaluation message is still coming .
    We also try for other various catalog, then also same error is still coming .
    Also we try at other 5 workstation by admin login and also by regular user's login, then also same problem coming.
    B>
    About second problem of updating catalog, we solved this updating problem at our end. Thank u.
    Waiting for your reply about first case.
    Thanks & Regards ,
    Swapnil M. Gholap
    Application Engineer
     s.gholap@frames-group.com
     Frames Process & Energy Systems India Pvt.Ltd.
    www.frames-group.com
  • Thank you for the feedback.
    I was able to reproduce this issue on my side as well. It was reported as Trouble Report D-98917:
    Component One VSFlexGrid8 dialog pops up in SpecGen Catalog Editor upon selecting any table if a spec is also open side-by-side along with a catalog in SpecGen
    Steps to Repeat:
    1. Open SpecGen
    2. Open any sample or user project.
    3. For the dialog ‘Open an existing spec’, open any spec like cs150. Keep it opened.
    4. Now open Catalog Editor (Catalog>Catalog Editor).
    5. Select any table from ‘Tables’ drop down.
    6. Error will occur.
    7. Repeat above steps in the same session and error won’t occur.
    8. Exit from SpecGen and re-launch. Repeat above steps, error will occur.
    It will be evaluated by the product management team for our regular SELECT updates.
    As a workaround: do not open Specification in SpecGen first before loading Catalog Editor
    Artiom
  • Respected Artiom,
    At present , our engineer is doing the same steps. But want to confirm that after clicking on "OK" , it will not affect our project's any data and databases or any files. Because we got 1 screenshot, attached with this.Please confirm the same.
    Waiting for confirmation.
    Thanks & Regards ,
    Swapnil M. Gholap
  • I have not noticed any negative effect. I would fully agree with Derek, that this is harmless message and no data will be effected.
    Artiom
