Hi All,
I want to convert .dwg 3d model into .dgn file using Bentley Autoplant v8i (Autocad 2012) .Please provide the steps for converting.
Thanks in advance,
shrinivas jadhav
Not the answer you want but I'm not sure that this is the right forum for this question. This is the MicroStation forum.
Unknown said: I want to convert .dwg 3d model into .dgn file using Bentley Autoplant v8i (Autocad 2012)
Try the Plant Design and Engineering Forum.
If you have MicroStation, you may publish AutoPLANT .dwg file to i-model, so you get *.i.dgn (read-only) in 3D.
Here may be an answer for you: communities.bentley.com/.../118140.aspx
Could you please explain a bit more what kind of functionality would you like. Do you just want to convert dwg to a dgn without any intelligence? Or do you want to convert AutoPLANT file to an OpenPlant model?
Justinas
Hi JustinasL
We want to convert .dwg to dgn.with intelligence.At present we are having 3d model autoplant v8i file & we want to convert into .dgn file.for this we are using export option in autocad 2012 but the conversion file not showing the 3d objects or piping it is only showing text or some 2d lines.
Shrinivas Jadhav
