Model file name sent to Isogen pcf file
I am trying to get a model file name to export into the Isogen pcf file. I'm not having any success. Has anyone tried to do this? I'm familiar with editing the opcfhdr.ebs file. However, I'm a piping designer not a programmer, so my knowledge is limited.
Currently running XM and Acad 2008
  • Hello Here is one of the way.
    This is a function that should be added to opcfhdr.ebs
    '// Function to write drawing name
    Public Function PCF_DRAWING_NAME(indentFlag As Integer) As Integer
      Dim nStat    As Integer
      Dim compID   As At_ComponentID
      Dim AreaName As String
      Dim documentName  As String
      nStat = at_Component_getCurrID(compID)
      status =  at_ComponentID_getDocumentName (documentName, CompID)
      documentName=FileParse$(documentName,3)
      documentName = UCase(documentName)
        If (nStat = AT_SUCCESS) Then
        If (indentFlag = 1) Then
          nStat = at_XchgWriteText ("    ")
        End If
        nStat = at_XchgWritelnText ("DRAWING NAME "+documentName)
      End If
      PCF_DRAWING_NAME = nStat
    End Function
    And Call for this function:
    nStat = PCF_DRAWING_NAME(2)
    As a result , heder should contain folowing information:
    ISOGEN-FILES isogen.fls
    UNITS-BORE MM
    UNITS-CO-ORDS MM
    UNITS-BOLT-DIA MM
    UNITS-BOLT-LENGTH MM
    UNITS-WEIGHT KGS
    PIPELINE-REFERENCE ISO-A100-U100-L100
    PIPING-SPEC MCS150
        AREA A100
    DRAWING NAME 123.DWG
        ATTRIBUTE31
        ATTRIBUTE32   6"
        ATTRIBUTE34   123, ds
        ATTRIBUTE99 END
     I hope this will help.
    Artiom
  • Thank You! It works perfect! I modified it slightly to give it an attribute number that I could place on the output drawing with the .pos file. There maybe another or better way to get it on the drawing than what I did, but it works! Thanks again for your help!
    Tommy
  • Thank you for feedback. Glad to hear it worked.
    According to Isogen Info document there is :-92  *  CLIENT-DRAWING-IDENTIFIER variable that could be used in POS files as well.
    Artiom
Reply Children
