I'm using AutoPLANT SS4 on AutoCAD 2012 on Windows 7 x64.
1) When using the command Update Components->Advanced Selection, the command doesn't work. When I press ok, the command is stopped.
2) When trying to create isometric drawing with IsoGEN using the Advanced Selection I getting an Error. Please see the attached file.
Is there a problem with the advanced selection?
Looking forward hearing from you.
Best Regards
Alex Bekker
Application Engineer
Mckit SYSTEMS
Hello Alex,
It seems this is a known issue and was reported in D-108933, D-109646
As a workaround, please download https://communities.bentley.com/cfs-file/__key/communityserver-discussions-components-files/275806/3225.projectservices.dll and copy it to :
C:\Program Files (x86)\Common Files\Bentley Shared\Plant V8iC:\Program Files (x86)\Bentley\Plant V8i\Bin\R18
Just in case please keep as back up copy existing files.
I hope this will help.
Kind Regards,
Artiom
Hello Artiom,
Thank you for your help.
The workaround didn't work. Is there anything else that we can try?
Alex
Could you please try to register the dll and try again.
Hope this helps!
Dinesh
IN order to follow up on this case.During live meeting we were not able to reproduce this issue.The possible solution remains accurate:
As a workaround, please download projectservices.dll and copy it to :
It could be that not all Bentley applications where closed during projectservices.dll replacement.
Hello Tom,
Problem is because of windows security Update.
Could you please try to uninstall windows security update "KB3139940" and reboot the pc.
Hope this helps. Looking forward to your reply.
Abhijit Bute
