Dear Bentley Family,
When we open any multiple (second/third) autocad drawing , its stuck at the point “At_start_doevents” as shown in the attached pdf-screesnshot. Its not going further . Due to this we are not able to open multiple drawing.
Please let me know any solution and why its stuck at this point .
Waiting for your earliest reply.
Note - We are using:
Software : Bentley Autoplant V8i - SS4 version : 8.11.9.140 , Autocad 2012-64Bit , Naviswork 2013 , Inventor Ultimate 2014-64 Bit , MS-Office 2010 - 64 Bit.
Hardware : Workstation Dell Precision T3600
Could always just disable the comm center in AutoCAD:
usa.autodesk.com/.../item
Hi Swapnil ,
Have you restarted your machine after disabling Communication Center in regestry? I have disabled Communication Center throug HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R18.1\ACAD-9001:409\InfoCenter\InfoCenterOn=0 restarded machine and ti did not start.
IfCommunication Center start is disabled it could be a diferent reason of this issue.
Artiom
Dear Artiom,
I disabled the InfoCenterOn=0 by my admin rights login on 3 PC.
Then I log-off and regular user login the PC.
Out of 3, at 1 PC the problem still comes while on other 2 PC the problem not occur yet.
Very Strange..
Please next let me know what to do ...
Thanks & Regards ,
Swapnil M. Gholap
Application Engineer
s.gholap@frames-group.com
Frames Process & Energy Systems India Pvt.Ltd.
www.frames-group.com
Hello Swapnil,
I could not find any other information that could be cause of this issue. It is strange that only on one machine this not helped. Is there any difference between system configuration of those machines?
All machine are of same configuration(Workstation Dell Precision T3600) and same software(Bentley Autoplant V8i - SS4 version : 8.11.9.140) installed on it. Really its very strange.... to see behaving differently....
Can we do any thing to close these 2 “WSCommCntr1.exe” and “WSCommCntr2.exe” background process permanently so that the drawing will not stuck again and again?
