hi, i using autoplant v8i ss3 and I would like to add a barcode to my isometrics when i run them through isogen. I can add the field I want to the POS file to get it to come out in the right position of the iso but i need to use a separate font for the barcode. The link below explains a little on how to add a different font to isogen but the explanationfo for the extended POS is laking an dth elink they have on it ofr a sampl file is not available anymore. Anyone have a sample POS file I can look at which shows how to get the font for the barcode to sit alonhside the font for the remainder of the isometric.
http://communities.bentley.com/products/plant/design___engineering/w/plant_design_and_engineering__wiki/4220.aspx
Hi kfitz,
thanks for pointing us of the incorrect link in the wiki. The sample POS file mentioned in that article can be found here: communities.bentley.com/.../47891.aspx
I've also updated the article to point to a correct location.
Let us know if that helps or if you'll need any additional guidance on this questions.
Justinas
Unknown said: hi, i using autoplant v8i ss3 and I would like to add a barcode to my isometrics when i run them through isogen. I can add the field I want to the POS file to get it to come out in the right position of the iso but i need to use a separate font for the barcode. The link below explains a little on how to add a different font to isogen but the explanationfo for the extended POS is laking an dth elink they have on it ofr a sampl file is not available anymore. Anyone have a sample POS file I can look at which shows how to get the font for the barcodeto sit alonhside the font for the remainder of the isometric.
There are plenty of barcode (lnear or two-dimensional) font programs that may help, even a barcoding library. Google it.
You can try to use some free barcode fonts, but I am not sure whether it is compatible with the device. Anyway, we are waiting for the later solution for the barcode creating issue.
Hi, Susanna.
I wonder do you have any good suggetions of fine Barcode scannners whose prcessing way is simple and fast. I want to classify my CDs by reading barcode. Any suggestion will be appreciated. Thanks in advance.
Best regards,
Arron
