Hi, when the designer places a standard valve from Autoplant i want a dialog to appear to give the valve a tag (not unique). Can anyone help?
If you Edit component and place the tag value in the TAG_NO field for a valve, it will be tagged on the iso.
However the dialog that is opened for control valves that includes the button to browse for tags comes from the cntinput.ebs in the same ..\modules\base\common\ folder. I would not advise, necessarily, changing this method for valves without a research into the repercutions.
Hello Ken,
It seems this should be quite possible. Valve input routine should be changed. I would recommend using input routine for control valves as example modules\base\common\cntinput.ebs. Default input routine for base valves is at_Valve_input and is in the file vlvinput.ebs.
Artiom
Which application are you referring to? AutoPLANT P&ID or AutoPLANT Piping?
