When I use update components, it doesn't allow me to remove the value, I can only select a different value. How do I remove the spool number?
In which application are you trying to do this?
If using AutoPLANT and intending to enetr no value for example "0". Please follow the steps below.
1. Create a new Spool and call it "0"
2. Now, go to Update componets and change the value of the selected components to "0"
Additionaly, to assign blank Spool id's.
1. Go to 'Piping > Piping Tools > Assign Spool ID's...'.
2.Remove the value from 'Starting SpoolID' (i.e., it's blank), then check 'Reassign Existing Spool IDs' and press 'Ok'.
3. Select all the components and complete the process. All spool IDs will be unassigned.
Hope this helps !
Answer Verified By: Karl Beranek
Thanks guys! It worked!
