insert a specific character like “ (shift+”) or ‘’ (double ‘)
Dear all,
We are currently using “PlantSpace Design Series V8 XM Edition”. Due to the nature of a specific project that we work on, we need to modify Pipe label at Design Series. Is it possible to change the attribute load file accordingly, in order  to insert a specific character like “ (shift+”) or ‘’ (double ‘) to an ATTR_NAME in Access database file ATTRDEFN?
  • Hi Manolatos,
    An example of what you are proposing would be most helpful.
    Is it for output on the drawing that you are needing the pipe label to be modified in this way?
    What you are suggesting for the label attribute is not possible, since you are only defining the position and type (amongst other things) of the label itself.  You are not defining the format etc.
    If it is the format of the pipeline that you want to configure (for annotating drawings), this is done in the annotation[units].lib file,
    Nic
