I'm using AutoPLANT SS4 on AutoCAD 2012.
How to set parameters for Bushing (COMP_LEN, THD_ENG_M, THD_ENG_R), so I would not get the break as shown in Screenshot?
Looking forward hearing from you.
Alex Bekker
Hello Alex,
Is this happening with some shipped specification or with the custom one? If this is a custom one, please check that there are no negative values in any fields (COMP_LEN, THD_ENG_M, THD_ENG_R, etc...). Just in case make sure this is not project specific, if no then it could be that some custom ebs files could influence component connection.
I hope this will help.
Artiom
Hello Artiom,
Thank you for your help.
It is a custom spec.
There are no negativ values in any field. Please see the screenshot.
There are no ebs files that were changed.
The user set the dimensions specified for ANSI-spec.
How he need to set these dimensions to be displayed properly in the drawing - I do not understand.
Alex
Hi Artiom,
I will clarify the question.
Please see the attached files: Spec, Catalog, Model (contains 2 small models).
The only thing that I changed in the catalog was the Comp_Len from 30.988mm to 64mm in the bushing component 2x1 and 2x1/2.
What else do I need to change to make the changed connection to be correct?
Thank you for additional information, it helped a lot.
I have edited bushing drawing ebs file to meet current requirements. It seems that by default bushing thread engagement should be equal half of the component length (both THD_ENG_R; THD_ENG_M)
Please open C:\Program Files (x86)\Bentley\Plant V8i\Modules\Base\piping\draw\bushing.ebs and edit Bushing_draw3D routine.
Sub Bushing_draw3D (compID As At_ComponentID, portPos() As At_Point, viewVec As At_vector)
Dim CADObj As Long '// Graphical CADObjects to be created Dim status As Integer '// Status code Dim pipeOD As Double '// Pipe diameter Dim engLen As Double '// Component length Dim port2Dir As At_Vector '// Port 1 direction Dim flag As Integer '// Flag to draw a centerline on hide Dim engageLength As Double '// Engage Lengt added by Artiom
status = at_Component_getReal (pipeOD, compID, "PIPE_OD_M") status = at_Component_getReal (engLen, compID, "COMP_LEN") status = at_Component_getVector (port2Dir, compID, "Port2.Dir")
status = at_Component_getReal(engageLength, compID, "Port1.EL") '// Read engageLength of Port1 added by Artiom '\\Call at_Point_translateByVector (portPos(1), portPos(0), port2Dir, engLen/2) Call at_Point_translateByVector (portPos(1), portPos(0), port2Dir, engLen-engageLength) '// Modyfied by Artiom
flag = AT_CYLINDER_CENTERLINEONHIDE CADObj = at_CADCylinder_create(pipeOD/2, portPos(0), portPos(1), flag)
End Sub
Please create a back up copy of the original file. I hope this will help. Please let me know the results. Kind Regards, Artiom
Answer Verified By: Joey
This helped me a great deal. Thanks.
In case some others came across this, I wanted to share a change that I made.
I was not happy with the busing being drawn as the pipe OD. It simply is incorrect. In the spec there is a property called FLATS. This is the dimension across the flats. I wanted to draw the cylinder that diameter rather than just the pipe OD.
Add this code under Dim engageLength As Double:
Dim flatDia As Double '// Get Flat dim from spec
Add this code under status = at_Component_getVector (port2Dir, compID, "Port2.Dir"):
Status = AT_Component_getReal (flatDia, compID, "FLATS")
Comment out: '//CADObj = at_CADCylinder_create(pipeOD/2, portPos(0), portPos(1), flag)
Add this code: CADObj = at_CADCylinder_create(flatDia/2, portPos(0), portPos(1), flag) '// Read Flat dia for drawing cylinder
