Working on AutoPLANT Piping SS4, how can I create an Isometric based on an external PCF file (and not from the AutoPLANT geometry)?
Jacques.
Hello Jacques,
Put PCF file to C:\ProgramData\Bentley\Plant V8i\xchg\pcf (or to location that is set in PCF Path field Project Administrator>Project Name> Isogen>Input)
Open AutoPlant and Load Impor/Export menu. Go to Impor/Export ISOGEN(PCF)>ISOGEN Interface. Select in PCF file and press RUN.
I hope this will help.
Artiom
Answer Verified By: Jacques - McKit
Artiom, thanks you for your fast and accurate answer.
Jacques Buzaglo
Support and Sales Manager Bentley Products
McKit Systems Ltd.
