AutoPLANT V8i SS4 and SS5 (tested both)
AutoCAD 2012
Hi Everyone,
It seems like it is not possible to place a General Wye in AutoPLANT. I added them to the CS150 spec, and the placement starts out fine but once you enter the CTR_END measurements in the dialog and press ok, you will see the following error at the command line:
Unable to insert Wye.Could not identify the branch and run indices.
I ran it in debug mode, and I was able to trace it back to TEE.EBS, where the function attempts to determine whether the centerlines of the component are symmetrical or not. This function fails somehow and that's where the error comes in.
I was able to work around this by modifying the methods.ini file entry for AT_GENERAL_WYE as follows:
[AT_GENERAL_WYE]ORIGIN_METHOD = %APP_DIR%\Util\Origin ; at_Wye_determineOriginDRAW_METHOD = %APP_DIR%\Draw\genWye ; at_GeneralWye_drawORIENT_METHOD = %APP_DIR%\Util\Orient ; at_Wye_determineOrientationINPUT_METHOD = Common\GenWye ; at_GeneralWye_DlgInputCENTERLINE_METHOD = %APP_DIR%\Util\Ctrline ; at_Wye_CenterlinePORT_METHOD = %APP_DIR%\Util\Ports ; at_Wye_definePorts;EQUIV_PORTS_METHOD = %APP_DIR%\Util\EqPorts ; at_InlineASym_determineEquivPorts //THIS METHOD WOULD NOT PLACE THE WYEEQUIV_PORTS_METHOD = %APP_DIR%\Util\EqPorts ;at_Wye_determineEquivPorts TAP_PORT_METHOD = %APP_DIR%\Util\TapPorts ; at_Tee_determineTapPortLocationPROP_METHOD = Common\CompProp ; at_ComponentProperties_setDATA_METHOD = Common\PipeData ; at_Piping_DataCOORDS_METHOD = %APP_DIR%\Util\Coords; at_Wye_defineCoordsJSM_OUT_METHOD = XCHG\JSM\GenWyeOut ; JSM_OUT_GENWYEPCF_OUT_METHOD = XCHG\PCF\TeeOut ; PCF_OUT_TEE;VALID_DATA_METHOD = Common\Tee ; at_Wye_validateAngles // THIS METHOD WOULD NOT PLACE THE WYEVALID_DATA_METHOD = Common\Tee ; at_Wye_validateAnglesMainCHANGE_PLANE_METHOD = %APP_DIR%\Util\chgpl ; at_BendBranch_changePlaneSPEC_UPDATE_DATA_METHOD = Common\SpecUpd ; at_SpecUpdate_NoUpdateCOG_PIPING = Common\BomDescr ; at_Branch_cog
This uses the same methods as the true wye for the adjusted (highlighted items) above. I think this should be logged as a defect so I am reporting it, but this workaround suits us for now. Thanks!!
Hi Jesse,
As always many thanks for your input. This issue is been already filed for a while as Trouble Report D-79163 and will be addressed in Auto Plant SS6.
This is a link to zipped tee.ebs file from SS6 that has required fixes. I have run a quick test and it seems it is working fine now
tee.ebs zip
Extract zip to C:\Program Files (x86)\Bentley\Plant V8i\Modules\Base\common. Keep existing file as back up, just in case.
Artiom
Answer Verified By: jwolfe
