Is it possible to store all catalog files and spec files and also other needed (i.e. lookup tables) files in ProjectWise?
Now we have to keep and modify all those access files in file system (C: drive and network drive).
Pekka
Yes, it works very well from ProjectWise. We would recommend moving the entire workspace to ProjectWise and managing all of it from there. this way, you only need to edit and/or maintain one set of files.
Hi, I'm not sure are we talking about the same issue. What I meant is that I want to edit OpenPlant Modeler specs directly from ProjectWise with Specification Generator. If this is possible it would be fine. But I don't know how to create workspace into ProjectWise for Spec Generator.
We are using managed workspaces with microstation and openplant modeler
Pekka,
Sorry yes I misunderstood. The Specification Generator has not been integrated with Projectwise. So, you must Export or Check out the specs, edit them and import or check them back in. I use the Export method so that I may place the specs anywhere I like.
