Using OpenPlant Modeler I am wanting to show a pipe that continues but does not need to be shown from start to end. I want to show it as broken instead of a straight line.
Hi chambliss31,
This should be possible using the "Break component" command in OpenPLANT Modeler. Please select the command from the Task menu and select the Pipe you would like to break.
Also, see the picture below for your reference. Hope this helps.
Dinesh Solanki
Thank you for the reply. I was looking to show it like this.With a few 3d commands I was able to capture what I was aiming for. Thanks!
Answer Verified By: dustin chambliss
