I am using AutoPlant Project Packager to pack and create backup of the project. It was working fine for last 3 years.
However now it gives error as "Error in Pack function: File already exists" and terminate the packing.
Does anyone know possible solution to this error?
Atul
Hello Atul Yadav,
Could you try to change save the package to a different path to see if it helps. What version of AutoPLANT are you using? Also, could you let us know if you are getting the errors for other projects as well?
Dinesh Solanki
Hello Dinesh,
I am using APLANT P&ID 08.11.10.182 version.
I also tried using different path but no luck.
This problem is for one project only. I can pack other projects without any issue.
Atul Yadav
Hello Justinas,
The upload dose not work. Zip file is @ 430MB. Is there another way of sending file?
Hello Atul,
Please, use this link to upload, it should be better: bentley.sharefile.com/.../rb05b5eb954f4a07b
Justinas
File has been uploaded now. Please check zip file named MWH_Project_Zip.
Have you received the file? Got chance to review folder?
Sorry for a bit delayed response. Yes I have got the file and reviewed it. It looks like the issue is caused because your project is not enabled for OpenPlant Isometrics, but you are using AP SS5 and it is expecting project to have OpenPlant specific files while packing.
Easy way to resolve this would be just opening Project Administrator, expanding the project in question and Enable it for OpenPlant by right click on OpenPlant Isometrics node and selecting "Enable for OpenPlant". This will copy a couple of config files required by OPIM and then it should be packed without an issue in packager:
I will also file a Defect for development to fix this simple mistake in future releases.
Please, let me know if this solution will work for you as well.
Answer Verified By: Atul Yadav
Yes, it worked and I could pack project without any issue.
I never thought that I would need to enable AutoPlant project for OpenPlant isometrics.
Thanks for your help.
