OpenPlant Specs & Catalogs on SQL Server
I wonder if there is any discussion on placing OpenPlant Catalogues and Specs in the SQL database.
We found out that mdb files don't work good in networking environment, what is especially incomfortable while working in standalone mode. Some cannot purchase ProjectWise (no matter for what reason...) and work efficiently using references, what brings very good results even for relatively big projects (Microstation and references are great!). However when Spec is in the network foder - as usually 'hangs up' from time to time, as even Microsoft says that this is single user format...
Parents Reply Children
