I am learning Auto Plant V8i and following the Bentley Learn server Plant Design Fundamentals. I am on the chapter covering Work Areas. I have set-up a work area and set the reference files and member status. However, I do not see my files referenced into my open drawing. I have re-saved all my reference files and current file to ACAD 2010 release and checked the work are settings. What is the likely reason I do not see my reference files?
It should work fine that way, strange. Maybe it's for some reason just do not save the settings? Is it the same for all files/work-areas or just with the one file? Can you also see if the dwg files are referenced to your model after you create a work-area by using 'xref' AutoCAD command?
Hope this helps,
Justinas
Answer Verified By: CADTech1
Justin,
I do not see the reference files. Are the reference files supposed to be automatically added when set-up the work area or do I add those manually?
