When using DataManager's 'Filter Builder' to filter on equipment types for example, the value list returned contains as many times the equipment types as there are equipment of each type.
Is there a way to modify the query populating the list so that it uses a SELECT DISTINCT to have only one value of each equipment type?
Alain
Hello Alain,
Unfortunately, this functionality is hard coded and there is no way for you to redefine these queries. However, there is already a Defect # D-83179 filed for this issue and it will be reviewed by the Product Management for possible a fix in the later versions of AutoPLANT application.
Justinas
Answer Verified By: Alain Magnan
Hello Justinas,
This is what I suspected. Thank you for confirming. It will surely not be fixed in DataManager XM and probably not in the V8i version but hopefully in the next generation of DataManager that will probably have "OpenPlant" in its name.
