Solid by extrution from 2D cell in GC
Hej ppl,
having another question about GC again.
We have our stand steel cross section as 2d cell libary, which can be placed in mircostation or with a GC node type 'cell'.
But if I want to extrude 2d cell into a solid, I couldnt find the correct method/option in solid node type.
please look at the attached pic here:
those steel cells are placed as 2d cell. I can extrude them manually by extrudtion tool, but GC node seems not really work.....
any ideas?? thanks
Leo
  • You need to extract ('promote') the curves from the cell first, then perform the solid extrusion. You cant extrude a cell object in GC. Also, if you have object types that are not promotable using the method I'm showing below, you'll need to do an exhaustive search for them using other element types then join them back together again:
    Answer Verified By: Mueller
  • Hi Tom,
    Could you elaborate a bit on the 'exhaustive search' that you would need to do in GC using the FromElementsinCell technique.
    Apparently, not a popular node. It would be good to highlight what can be improved.
    I think that GC would benefit if it wasn't stymied every time it has to deal with grouped elements or elements in Cells.
    In the BIM world, we are compelled to work with 'objects' not just geometric elements ie doors and not just lines and arcs symbolising a door. This means GC needs to play well with Cells and nested elements.
  • Not all 'curve-like' objects cast, so you may need to use for example the Arc to extract arcs in the cell if Curve.ElementsInCell fails in cases where you have multiple curve types in one object. In these case, I typically write a simple script which recursively promotes all possible curve types in a cell so nothing gets left behind, hence 'exhaustive search'.
    I wrote this table for users I used to train at my previous office to help them to promote different object types which you (or others) may also find useful.  This was using SS3 not SS6 which I've not tested to any great depth and it may have resolved this issue entirely since the promotion techniques are brand new implementations:
  • hej Thomas, it work fine in my case, as all the cross sections are very neat made by profressionals. so cell to curve to extrutioin works prefectly well here. I am expecting some broken curves may happen, but I think I can fix them by remaking the cell.
    but I do agree with the others, GC needs to be polished a little to meet the requirement as a BIM progam if it is the way GC is working towards. thanks for your help.
    Leo
