so we are having problem creating a component. using the floater " generate node type " , I think I am following all the necessary steps but the OK button does not get activated to complete the process. ie. to create the component. any clue whats going on ?
Thanks in advance. arman
Hello Arman,
Your post contains to little information for me to venture a guess. Usually an inactive OK button on the Generate Node Type dialog indicates that some required input is missing.
Here is a checklist:
The OK button should activate after 3.
To help you further, please post a screen capture of the GNT dialog in this thread or send it to me at Volker.Mueller@bentley.com. I will be able to analyze the issue even better if you also include the GC model from which you are attempting to generated the GNT.
Volker
